Yealink New Firmware V82
Discussion in '3CX Phone System - General' started by Brad Cann, Nov 9, 2017.
  1. Brad Cann
    Brad Cann New Member
    May 5, 2017
    111
    16
    Gday All,
    All my phones are V81 firmware and the new firmware appears to have come out and been released to 3cx. However when i try to deploy that firmware via phone and +Firmware, all the phone does is reset but doesn't update. I am wondering if it is something similiar to the yealink conference phone issue from a while back?
  2. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    Interestingly, I'm having the same issue but only at my remote sites. Which is odd, as it's worked before.
  3. Brad Cann
    May 5, 2017
    111
    16
    i just had a look in the program data folder and the t42-29.82.0.20.rom file is only 1kb in size??? i'm guessing there was some kind of download fudge that happened during the download. Interestingly enough there are a few of these 1kb new .rom files all of which contain in the file itself:
    <head><title>Document Moved</title></head>
    <body><h1>Object Moved</h1>This document may be found <a HREF="http://www.3cx.com">here</a></body>
    So i'm guessing that when 3cx got the downloads, they possibly moved the files when i was downloading them or hadn't uploaded them fully and we got these downloaded ....
    So i'm guessing that we need to delete these files and wait for a recheck or delete the files and restart services if it is urgent.
  4. Brad Cann
    May 5, 2017
    111
    16
    So after redownloading them files manually from the yealink website and replacing the 1KB size files, the firmware update button is now working. Hopefully this fixes some other folks issues.
  5. Brad Cann
    May 5, 2017
    111
    16
    aaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhh, once the file was replaced, the phone firmware i tried to push across the network last weekend must've stayed as pending, as i just had 50 odd phones reboot and apply the firmware since the file is now working.....
    Queue much swearing and panic...........................
    Is this a feature or a bug?
  6. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    Hmm... my file sizes are correct. But I had a phone onsite have the exact same issue, ruling out VPN as the culprit. Still not sure what the deal is.
