Yealink phone auto answer
Discussion in '3CX Phone System - General' started by 805tech, Apr 8, 2015.
  1. 805tech
    Aug 30, 2013
    39
    We are having a issue when someone is logged in to the Queue and they get another direct phone call at the same time the phone will automatically pick up the direct phone call. I have checked the settings and auto answer is off. I have looked at the Yealink forums and from what I have read they say its a issue with 3CX. Is there a way so the phone does not auto answer this is a feature we do not want.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Are you running phone in CTI in association with a 3CXPhone ?
    Does your extension have the option "I want to be able to accept more than 1 call at the same time" enabled ?
  3. metheridge
    Dec 16, 2014
    12
    I am having the same exact issue . Hopefully this is easily fixed.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Is there more than 1 account assigned to the same phone?
    I just tested this on our system and it did not occur on v12, stock T48 template.
    The phone does accept multiple calls...
    and CTI mode did not matter. It did not happen in either mode.
  5. gbardissi
    Feb 4, 2015
    28
    Yes we have seen and documented this issue. There is a workaround. I will post that to the LinkedIn group
  6. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    Having a similar issue with T48G could you share the workaround?
  7. certainlyNotApenguin
    Aug 25, 2015
    I'm also have this issue, if someone finds a solution please post!
  8. bardissi
    bardissi Member
    Jan 31, 2012
    318
    https://www.linkedin.com/grp/post/3157738-6001812374888202240?trk=groups-post-b-title
  9. certainlyNotApenguin
    Aug 25, 2015
    Brilliant thankyou!
