Yealink phone show someone on phone
Discussion in '3CX Phone System - General' started by pukkainc, Oct 20, 2016.
  1. pukkainc
    Apr 27, 2016
    45
    With our old phone system, when you dialed an extension and that person was on the phone, the actual physical phone would display a message that the user was on the phone.
    Is this possible with 3CX? We are using Yealink T27P phones. I am on version 14 of 3CX.
    Thanks!
  2. pukkainc
    Apr 27, 2016
    45
    Any ideas?
  3. bdarcyevans
    Apr 6, 2015
    50
    If it's viable, consider getting your users to use 3CXPhone on their PC/device. This will give them presence/status information and lots of additional functionality.
  4. briankayser
    Jul 19, 2016
    49
    5
    Not that I've run across. You could of course configure the phone to not accept more than one call at a time, then if the settings are such that it doesn't go to voicemail but disconnects the call, they will get a 486 BUSY message on their screen. However I doubt that is what you are going for...
