Yealink phones and option 66
Discussion in '3CX Phone System - General' started by nutel1, Dec 17, 2014.
  1. nutel1
    Oct 22, 2014
    23
    I set up a DHCP server and have been testing option 66 to send the provisioning server url to the phone. The only way I can get this to work is if I go into the gui of the yealink phone and disable only accept trusted certificates. This kind of defeats the purpose of option 66 if I still have to go in first and turn this setting off. Am I missing something? Does anyone have some suggestions?
    Thanks.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,977
    183
    what firmware of yealink and what phone specifically?
  3. nutel1
    Oct 22, 2014
    23
    T46g 28.72.0.45
  4. craigreilly
    Feb 1, 2012
    2,977
    183
    I am on 28.71.0.224 which is the recommended version... they must have added some certificate bs thinking it would be more secure - but if your server is not running https with a valid cert then you are hosed.
  5. nutel1
    Oct 22, 2014
    23
    so on your version, trusted certificates is disables in default? I will try will just http and see what happens.
