Yealink Power LED on VM Only
Discussion in 'Ideas' started by Matthew Domer, Mar 3, 2017.
Yealink Power LED on VM Only 5 5 2votes
5/5, 2 votes
  1. Matthew Domer
    Mar 3, 2017
    After upgrading to the latest firmware and Yealink templates users report that their red LED now flashes on missed calls, not just voice mails. Everyone relies on this LED for voice mail notification. None of my clients so far like this new "feature". I would ask that the following line be added to the T4x default template:
    phone_setting.missed_call_power_led_flash.enable = 0
    mattebowman likes this.
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    That's a personal preference. I like the "missed calls" pop-up and light flashing. When I clear the pop-up the light stops. I get my voicemails by email ...
    You know it's easy to have your own custom templates right ? Work on your own that's just the way you and your customers like it and use it on all your installs.
