Yealink Provisioning Template Does Not Work For Send Volume
Discussion in '3CX Phone System - General' started by Grand Archer, Jul 22, 2015.
  1. Grand Archer
    May 27, 2015
    6
    I am running 3CX V12.5 and am pushing the template for Yealink T32G phones running firmware version 32.70.0.221. I changed the following settings.
    voice.handfree_send = 25
    voice.handset_send = 35
    voice.headset_send = 29
    When I change these to anything else within the valid range of 1 to 53 and re-provision the phone these settings do not take affect but all the other settings do. Is the provisioning template wrong or am I missing something here.
  2. jasit
    jasit New Member
    Feb 12, 2013
    169
    Re: Yealink Provisioning Template Does Not Work For Send Vol
    did you manually reboot the phone after the reprovision?
    #Configure the sending volume of Speaker, Handset and Headset. It ranges from 1 to 53, the default values are 25, 35, 29.
    #Require reboot;
  3. Grand Archer
    May 27, 2015
    6
    Yes I did reboot the phone manually SEVERAL TIMES to no avail. Not sure what I'm missing here. Got email back from YEALINK stating that the config is right and it should take and they have no explanation as to why it wont work. I am dead in the water at this point if I can't get this figured out.
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    Have you try first a reset to factory defaults and then reprovisioning the phone again?
