Yealink provisioning template
Discussion in 'Ideas' started by complex1, Jul 12, 2017.
Yealink provisioning template 5 5 4votes
5/5, 4 votes
  1. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    Please change the Yealink templates to prevent unauthorized login via User or Var account, to keep hackers outside the phone.
    After provisioning, the User and Var account are still open for everybody.
    Painful detail: One of the phones was hacked this way and the costs ware $1000
    Code:
    ##                                Security Settings                                  ##
    #Enable or disable the phone to only accept the certificates in the Trusted Certificates list;
    #0-Disabled, 1-Enabled (default);
    {IF $uagroup=NoSSL}
    security.trust_certificates = 0
    {ELSE}
    security.trust_certificates = 1
    {ENDIF}
    #Define the login username and password of the user, var and administrator.
    #If you change the username of the administrator from "admin" to "admin1", your new administrator's username should be configured as: security.user_name.admin = admin1.
    #If you change the password of the administrator from "admin" to "admin1pwd", your new administrator's password should be configured as: security.user_password = admin1:admin1pwd.
    #The following examples change the user's username to "user23" and the user's password to "user23pwd".
    #security.user_name.user = user23
    #security.user_password = user23:user23pwd
    #The following examples change the var's username to "var55" and the var's password to "var55pwd".
    #security.user_name.var = var55
    #security.user_password = var55:var55pwd
    security.user_password = user:%%DESKPHONE_PASSWORD%%
    security.user_password = admin:%%DESKPHONE_PASSWORD%%
    security.user_password = var:%%DESKPHONE_PASSWORD%%
    #Enable or disable the 3-level permissions (open var); 0-Disabled (default), 1-Enabled;
    #Require reboot;
    security.var_enable =
