yealink provisioning
Discussion in '3CX Phone System - General' started by netswork, Apr 5, 2012.
  1. netswork
    netswork Active Member
    Mar 11, 2011
    577
    My customer has some t.28's and t.38's. I would like to setup the provisioning so that it only has the phones extension on the first 2line buttons and the rest of the line buttons and side buttons can be used for BLF or whatever. Anyone understand the yealink config files and point me in the right direction for configuring that? Thanks in advance
  2. willow
    willow Member
    Mar 1, 2011
    471
    you can modify the template in 3cx, there is a section that ssigns account 1 to button 10 - 16. just assign account 1 to 10 and 11 and you should be good to go..
  3. netswork
    Mar 11, 2011
    577
    Thanks for the reply. I am guessing what you are referring to is in the below section...I am not certain what to modify.
    #Set Memory key1
    [ memory1 ]
    path = /config/vpPhone/vpPhone.ini
    {IF blf1}
    Line = %%Line%%
    type = %%type%%
    Value = %%blf1%%
    DKtype = %%DKtype%%
    PickupValue = %%PickupValue%%
    {ELSE}
    type=NA
    {ENDIF}
    [memory2]
    path=/config/vpPhone/vpPhone.ini
    {IF blf2}
    Line = %%Line%%
    type = %%type%%
    Value = %%blf2%%
    DKtype = %%DKtype%%
    {ELSE}
    type=NA
    {ENDIF}
    [memory3]
    {IF blf3}
    Line = %%Line%%
    type = %%type%%
    Value = %%blf3%%
    KEY_MODE = Asterisk
    HotNumber =
    HotLineId = 1
    Callpickup =
    IntercomId = -1
    DKtype = %%DKtype%%
    {ELSE}
    type=NA
    {ENDIF}
    [memory4]
    {IF blf4}
    Line = %%Line%%
    type = %%type%%
    Value = %%blf4%%
    DKtype = %%DKtype%%
    {ELSE}
    type=NA
    {ENDIF}
    [memory5]
    {IF blf5}
    Line = %%Line%%
    type = %%type%%
    Value = %%blf5%%
    DKtype = %%DKtype%%
    {ELSE}
    type=NA
    {ENDIF}
    [memory6]
    {IF blf6}
    Line = %%Line%%
    type = %%type%%
    Value = %%blf6%%
    DKtype = %%DKtype%%
    {ELSE}
    type=NA
    {ENDIF}
    [memory7]
    {IF blf7}
    Line = %%Line%%
    type = %%type%%
    Value = %%blf7%%
    DKtype = %%DKtype%%
    {ELSE}
    type=NA
    {ENDIF}
    [memory8]
    {IF blf8}
    Line = %%Line%%
    type = %%type%%
    Value = %%blf8%%
    DKtype = %%DKtype%%
    {ELSE}
    type=NA
    {ENDIF}
    [memory9]
    {IF blf9}
    Line = %%Line%%
    type = %%type%%
    Value = %%blf9%%
    DKtype = %%DKtype%%
    {ELSE}
    type=NA
    {ENDIF}
    [memory10]
    {IF blf10}
    Line = %%Line%%
    type = %%type%%
    Value = %%blf10%%
    DKtype = %%DKtype%%
    {ELSE}
    type=NA
    {ENDIF}
    #Memory 11 to 16 are used for Line Keys
    [memory11]
    Line = 1
    type =
    Value =
    DKtype = 15
    PickupValue =
    [memory12]
    Line = 1
    type =
    Value =
    DKtype = 15
    PickupValue =
    [memory13]
    Line = 1
    type =
    Value =
    DKtype = 15
    PickupValue =
    [memory14]
    Line = 1
    type =
    Value =
    DKtype = 15
    PickupValue =
    [memory15]
    Line = 1
    type =
    Value =
    DKtype = 15
    PickupValue =
    [memory16]
    Line = 1
    type =
    Value =
    DKtype = 15
    PickupValue =
  4. willow
    willow Member
    Mar 1, 2011
    471
    yep that's it! just leave 11 and 12 unchanged and you can either set 13-16 to a different account or a blfs manually.
  5. netswork
    Mar 11, 2011
    577
    Thanks willow, once I got all of the options figured out it worked well.
