Yealink & Raspberry Pi - How Get Latest Phone Configuration
Discussion in '3CX Phone System - General' started by uptime1, Jun 21, 2014.
  1. uptime1
    uptime1 New Member
    Jan 13, 2012
    112
    30
    3CX Cloud v12 SP6
    When using a Yealink T46G behind a Raspberry Pi Session Border Controller, what is the proper method to pull down the latest phone configuration (say you made a change to the BLF's) without having to factory reset the phone?
    I tried Phones Reboot, Reprovision Phones and Reset & Reprovision which are all available (black text), but nothing happens.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Re: Yealink & Raspberry Pi - How Get Latest Phone Configurat
    Reprovision button should work, are you all uptodate on raspberry ?
    Can you perform these commands and see if anything pending :
    sudo -s
    apt-get update
    apt-get install 3cxsbc
    apt-get upgrade
    Also are you running latest supported firmware on yealink t46 (28.71.0.224)?
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,069
    201
    PJ -
    Don't those commands just update the Pi and not the phone config itself?
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi Craig,
    Yes you are correct it will update the pi packages and the 3cxsbc, as I suspect your issues are related to something out of date.
    Is your T46 also running latest supported firmware ? (28.71.0.224)
