Yealink Record BLF
Discussion in 'Ideas' started by jeroendebruijn, Mar 17, 2017.
Yealink Record BLF 5 5 3votes
5/5, 3 votes
  1. jeroendebruijn
    Nov 9, 2015
    35
    16
    For Yealink T4x Devices, please add the blf option to record calls.
    Right now, I am doing this manual for almost all our customers. In fact even i it is one of the most requested features, even if in the end they do not use it.
    It only needs to set 2 fields:
    Value=25
    and the label (even there I would be happy with a default " Record"
    Troy.Ferrell likes this.
  2. techclarity
    Nov 14, 2014
    90
    36
    Would like to have this feature as well.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,970
    183
    So it sounds like you know how to do this already...
    Settings - Template - T48 - Copy Template - Update BLF on button x.
    No need to do it manually.
    Or perhaps you are asking them to update the Extension Edit template with a new BLF button type...
  4. jeroendebruijn
    Nov 9, 2015
    35
    16
    @craigreilly
    Yes, I ant them to edit the BLF section of the extentions to add the Record option.
    Mostly because adding this manually to a template is a direct
    '"This is not a 3cx supported template" reply form support.
    I can realy get annoyed by such replies.
    Besides, It seems to me that : yest, it mght take a few lines of code, but it should not be too hard to implement this for 3CX.
    Troy.Ferrell and craigreilly like this.
