Yealink ring tones different across models
Discussion in '3CX Phone System - General' started by integrity2, Feb 2, 2013.
  1. integrity2
    Nov 10, 2009
    22
    Until the last firmware upgarde, all of our Yealink phone ring tones were the same. We have the T28's and the T38's.
    I installed the 2.70.0.103 update from here http://www.yealink.com/SupportDownloadfiles_detail.aspx?CateId=184&flag=142 and after that all of the ring tones changed from what they were - and different between the two models.
    I'm sure I can edit the provisioning profiles to get them to be the same. Just wondering if this is the correct approach!
    ...or should I just install the 2.70.0.130 - that doesn't say it has official 3CX support?
  2. dlazure
    Nov 5, 2012
    65
    editing the template sound the best way to me
    im wondering why they changed the ring tones tho
