Yealink ring tones
Discussion in '3CX Phone System - General' started by mixig, May 17, 2012.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    is there any place on Internet where I can download ring tones for yealink phones for free? or some application/tutorial how to convert e.g. mp3 so that they can be uploaded to yealinks?
  2. paul.hadley
    paul.hadley New Member
    Aug 24, 2010
    122
    http://www.888voip.com/forum/yealink/600-creating-wav-files-for-yealink-ringtones.html
  3. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    Thanks, I also found that... i will try with that.. I hoped that someone will gave me converted ring tones so that I can just upload them to the phone :roll:
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,401
    273
    And even that doesn't seem rock solid. I tried with a wav file - trimmed it down to 100k, mono, etc.
    then processed thru SOX and it didn't use that tone -
    The next wav file I tried worked.
  5. paul.hadley
    Aug 24, 2010
    122
    This is the program I usually use to edit and modify the format of .wav files. I have not used it for Yealink phones but it is fine for Polycom and Grandstream ringtones and for doing sound files for the 3CX IVM so I guess the format you require should be available.
    http://www.nch.com.au/components/wpsetup.exe
  6. snowsam
    May 26, 2011
    79
    If you have users wanting the old ring tones back from v60 or v61 after upgrading to yealink's v70 firmware, here is the thread over on the yealink site: http://forum.yealink.com/forum/showthread.php?tid=165
    At this point, support has provided the old tones, but the tone people want is too large to upload back to the phones via the web interface.
