Solved Yealink RPS server
Discussion in '3CX Phone System - General' started by OCWI, Aug 5, 2017.
  1. OCWI
    OCWI New Member
    Jan 17, 2017
    159
    46
  2. OCWI
    OCWI New Member
    Jan 17, 2017
    159
    46
    Looks like its through the distributor, fine.
    My question stems from this. Some phones i have in the field were provisioned as stun at one point in time for whatever reason. We have since then factory reset them and reprovisoned them using a SBC.
    That all works fine, except i cant update the firmware on those from the 3cx GUI. From what I've read it seems like it just a matter of removing them from this RPS server. Does that sound right?
    Any directional advice would be appreciated.
  3. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    734
    113
    No that doesn't sound right. At the end of the day RPS just helps the phones find the provisioning server. So if the phones are provisioning, then the RPS server is not stopping you. What is stopping you is you can't push firmware when the phones are on SBC. If you search the forums you will see many complaints about the lack of remote management of phones when setup via SBC compared to STUN
  4. StefanW
    Jun 2, 2009
    1,199
    79
    SBC and STUN both use "public URLs" to provisioning and also for the firmware upgrade process. Therefor this should not cause any issues to witch a once connected phone from STUN (RPS) to SBC. Also 3CX de-lists all device within 2 weeks from the RPS service and with this there is no info anymore that the phone was once a STUN device...
    OCWI likes this.
  5. accentlogic
    accentlogic New Member
    Nov 14, 2013
    161
    66
    We had the same issue. If phones were provisioned using RPS with the SBC method then we could not push out new firmware or re-provision the phones. If the phones are provisioned using PnP (3CX sees the phone behind an SBC, assign to extension) then firmware and re-provisioning works fine.
    For now, we are not using RPS for SBC sites. With the new configuration options in v15.5sp1 we have almost no need for custom templates, which was why we wanted to use RPS. (PnP does not provide an option to use custom templates as it detects the correct stock template.)
  6. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    170
    59
    @StefanW - Factory reprovision is our "go-to" solution for when phones don't work. If the phone is removed from RPS after two weeks, how can we push it back into RPS? Re-Enter the MAC and save?
  7. OCWI
    OCWI New Member
    Jan 17, 2017
    159
    46
    Thanks for insight guys! this has helped!
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    You can click edit and ok on the extension which the phone is provisioned to and the PBX will re-send the RPS request. The phone must have STUN as the provisioning method
  9. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    170
    59
