Yealink SIP T27G
neville
Gold Partner
Any idea when the Yealink SIP T27G will be supported?
The Yealink T27G is not a supported phone, it has not been tested by our side and its behaviour with the system is unknown.
You can manually provision the phone at your own risk.
Unfortunately, we have no time frame for getting support and I am not in the position to know since this is handled by another department. Please keep an eye on our website
Thank you
You may provision it as T27P. As the difference should be only the network interfaces, it should be working normally, probably wise not to upgrade its firmware from 3CX.
I have several T27G units that shipped with v81.0.15 firmware. Line key issues, but you can make and recieve calls. But, BLF and Shared Parking do not work. Can't deploy them to the client until these are resolved.
Get 3CX - Absolutely Free!
3CX
