Solved Yealink SIP-T58 Update Fail
Discussion in '3CX Phone System - General' started by teldata1, Aug 29, 2017.
  1. teldata1
    Aug 24, 2015
    63
    When I try to update the phone firmware for the Yealink T58 phone through the updates page, it takes about 5 minutes then fails with a message saying something like "Failed to connect to 3CX Update Server." Anyone else experiencing this issue?
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    841
    125
  3. teldata1
    Aug 24, 2015
    63
    Not what I mean. I'm talking about downloading the Firmware from the 3CX updates server (the same way you would download a service pack update, or SIP trunk update etc.)
  4. Saqqara
    Mar 12, 2014
    841
    125
    Does nslookup return the correct IP address
    Do normal updates work ?
    Are you blocking any ports, etc on the firewall ?
    Could be an issue with 3cx servers and the firmware - unable to download
  5. teldata1
    Aug 24, 2015
    63
    I was able to download other updates just now, as there were 4 new SIP trunk templates. So I'm thinking the issue is specifically with the T58 firmware on the 3CX update server
  6. Saqqara
    Mar 12, 2014
    841
    125
    Would agree, issue with 3cx servers - unable to download manually from previous url
  7. teldata1
    Aug 24, 2015
    63
    Just retried downloading from the URL, worked this time... weird.
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Glad to hear the download worked. I would suspect the download timed out as the firmware for the specific phone is quite large. If you experience the issue again try replicating while running a wireshark capture so we can see the reason of the failure
