Yealink SIP-T58
Discussion in '3CX Phone System - General' started by D Caviness, Jun 26, 2017.
  1. D Caviness
    Apr 18, 2017
    20
    Just got our batch of Yealink 5-series. Notice that we can't auto-provision since there isn't a template assigned for the 5-series yet. the T58 shows up in the Phones list but can assign an extension (greyed out).
    Is an update to support these phones coming soon?
  2. Lucas Christensen
    Feb 16, 2017
    It runs android. Can you just download the 3CX app from the app store for now?
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    380
    50
    Configure the extension manually as a Yealink T48S in 3CX. Then either use DHCP66 or if remote stun or sbc you will likely have to put the provision path into the phone manually. These phones use Yealink 80/81 firmware which 3CX v15/v15.5 template works well with. May not be a perfect solution but it will likely register and work. Report back I'd be interested to hear.
    teldata1 likes this.
  4. D Caviness
    Apr 18, 2017
    20
    Thanks, that seemed to work with my DHCP Option 66 setup. It rebooted twice and came up with all the configurations within my custom T48S template.
  5. Grizz
    Jun 28, 2017
    I'm here trying to figure out how to provision a T58V with 3CX app... is there a place to manually edit the file?
  6. D Caviness
    Apr 18, 2017
    20
    If you are running ver. 15.5:
    1. Settings -> Templates
    2. Choose the template YealinkT4X
    3. Click Copy and Rename
    4. Make Global edits and edits tied to the T48S model
    5. Save
