Yealink T19, DHCP option 132, and Phones Page
Discussion in '3CX Phone System - General' started by cobaltit, Jun 26, 2015.
  1. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,561
    237
    @DennisT
    If the phone isn't making a broadcast, that would make a it a Yealink issue (or feature request). So you would be better off either posting in the Yealink forums or reaching out to Yealink support via support@yealink.com or if you are in the USA, support.usa@yealink.com
