Yealink T20 and T22
Discussion in 'Windows' started by stash, Sep 24, 2012.
  1. stash
    stash New Member
    Feb 23, 2012
    213
    I have a couple of problems.
    Incoming call from external caller the phone is blinking indicating that someone is calling but no ringing.
    Outgoing call from external call you don't hear ringing until it was answered by the person you are trying to call.
    I'm using Grandstream FXO gateway for my trunkline. This only happens on 2 whole ring group.
    Thanks,
    STASH
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,560
    301
    You might have better luck in the General Forum as this one is dedicated to 3cx SoftPhone for Windows.
