Yealink T20P and 3CX ver 15 SP4
Discussion in '3CX Phone System - General' started by GR8Metal, Feb 14, 2017.
  1. GR8Metal
    Feb 14, 2017
    Hi All,
    I have 3CX version 15.0.60903.0. I have a large fleet of Yealink SIP-T20P phones. I’ve noticed that these models are on 3CX's “end of life” list. However, the latest firmware version that was supported was 9.73.0.60. When I try to apply this firmware version which is available from the upgrade firmware section of the 3CX management page, it does not apply. Also, this firmware version is not available from Yealink’s download support page. Does anyone know where I can get this firmware version (9.73.0.60) for the SIP-T20P phones and if I manage to get my hands on this and apply this firmware to the phones, will the phones work successfully on 3CX 15.0.60903.0?
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi GR8Metal,
    You can download from the management console Updates=> Phone firmware => select the needed firmware and download it.
    For windows you can find it on this location C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\%RandomFolder%\firmware_new\Yealink on your server
    For Linux you can find it on this location
    /var/lib/3cxpbx/Instance1/Data/Http/Interface/provisioning/%RandomFolder%/firmware_new/Yealink
    On this link you can find step by step firmware upgrade of yealink phones.
    https://www.3cx.com/sip-phones/firmware-update-yealink/#h.mscc2luoyt12
    #2 GiannosC_3CX, Feb 14, 2017
    Basaran likes this.
  3. Basaran
    Apr 1, 2011
    13
  4. Thomas Kenyon
    Aug 29, 2017
