Yealink T21P E2 support
Discussion in '3CX Clients' started by Marksp, Jun 12, 2017.
  1. Marksp
    Jun 12, 2017
    I run a small business in Brazil and I'm testing 3CX with two units of the T21P E2. It turns out that I really like this phone, it's cheap and the loudspeaker function is great for us. I would like to know if someone can tell me if this phone will continue to be supported by the 3CX phone system. I'm asking this because, although everything seems to work fine, the management console is showing messages like "unsupported" after provisioning on the newest firmware.
    Thanks for the help!
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @Marksp,
    The management console is saying un-supported because the phones are not on the supported firmware. For V15.5 the supported firmware is 52.81.0.61. The management console will also tell you the phone is un-supported if you use custom templates.
  3. clovanzo
    May 10, 2017
    I have same problem (T19P_E2) try to press the firmware to upgrade it but the phone only restart. I can not find 53.81.0.61 version on their website for manual firmware upgrade. Can you please give me the link firmware for that version?
  4. YiannisH_3CX
    May 10, 2016
    4,349
    274
    The firmware for the phone is already downloaded on your PBX. If you are running it on linux then the path is
    /var/lib/3cxpbx/Instance1/Data/Http/Interface/provisioning/RANDOM_FOLDER/firmware_new/yealink
    For windows the path is:
    C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\RANDOM_FOLDER\firmware_new\yealink
  5. clovanzo
    May 10, 2017
    Thank you.
