YeaLink T21PE2 and BLF
Discussion in '3CX Phone System - General' started by petewatterschats, Mar 1, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    Assigned and extension to YeaLink T21PE2 and the phone is working
    Under Extension - BLF
    I created entries
    2 - Shared Parking - Shared Park extension 0
    3 - Speed Dials - 300 Joan logan
    4 - Custom Speed Dial - John's cell 1-818-987-444
    5 - Change Status - Available
    6 - Change Status - Away
    7 - Change Status - Do Not Disturb
    8 - Change Status - Lunch
    9 - Change Status - Business Trip
    Is it Possible to use these on the Yealink and if so how do I do it
  2. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Looking at the template, T21P has two line buttons. You can configure those - you probably want the first to actually be a line button though, the second one can be whatever you want, so you could pick one from your list.
    That's probably not what you want - so - use the 3CXPhone in CIT mode. you can have as many buttons as you want with 3CXPhone :). Just configure the BLF's for the extension.
    Note that you'd need to customize the yealink provisioning template to change the buttons from Line. I was recently taught how to do that with help here ... but honestly, I wouldn't bother when the 3CXPhone is so much more flexible, and, you don't have to customize anything and hope it survives updates.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    253
    the t21 does not have any BLF buttons that are separate from the Line buttons. So - 2 buttons total.
