Yealink T22 LCD display character
Discussion in 'Windows' started by miro, May 2, 2012.
  1. miro
    Jan 17, 2012
    51
    users which are in ring group or queue during the incoming calls on their T22 Yealink LCd display can see only name of the ring group/queue but they dont see caller ID with T20 which also has 2 lines display in first we can see name of the ring group and on second we can see caller ID number.
    How to solve this issue, we have several costumers who have noticed that issue.
    Best regards.
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    General->Global Options->Append/Prepend name to caller ID:
    append-> callerID:group_name (***this will work for caller id on display***)
    prepend->group_name:callerID
