Yealink T22 T28 support
Discussion in '3CX Phone System - General' started by brentrichburg, Mar 2, 2018.
  1. brentrichburg
    Nov 16, 2010
    30
    I have about 250 combined count of Yealink T22 and T28 phones in my system. Is there a way that I can provision the phones? I understand firmware may be ended, but now I can't reuse a phone on a different extension and have it provision.
  2. eddv123
    eddv123 Active Member
    Aug 15, 2017
    882
    132
    There are still templates for these in 3CX so you can use PnP provisioning as long as they appear in the phones list.
    If they don't you need to investigate why they don't: https://www.3cx.com/docs/plug-and-play-ip-phone/
    The other thing you can do is setup your extensions and take the provisioning link off the extensions and manually enter them into the phones interface.
    YiannisH_3CX likes this.
  3. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    857
    126
    Delete the current config with the console, i.e delete the old extension, or delete the phone config under the extension if you more than one phone under the extension
    do a factory rest on them (pressing the OK button for awhile), then you can provision them according to the info in this url https://www.3cx.com/sip-phones/yealink-t20p-t22p-t26p-t28p/
    #3 Saqqara, Mar 3, 2018
