Yealink T23G "Make Call"
Discussion in '3CX Phone System - General' started by Jaymei, Jun 18, 2015.
  1. Jaymei
    Dec 18, 2014
    28
    Hi all,
    Wondering if any of you have encountered this happening on the T23G phones.
    We have them locally provisioned in CTI mode but when using the softphone app to dial it is coming up as "Make Call".
    All the phones are set to In Office.
    As you can imagine this is far from ideal and puts our users on Hold whilst connecting the call.
    Cant see anywhere in the template to change this to the same functionality as the T22.
    If anyone has a solution it would be much appreciated!
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi Ian,
    Kindly open a support ticket through your reseller on our support portal so that we can help further on this issue.
