Yealink T26 Time not incorrect
Discussion in 'Windows' started by markslowe, Jan 4, 2013.
  1. markslowe
    Jan 4, 2013
    5
    We have upgraded our Yealink T26/T28 to the latest supported firmware 6.70.0.103 and 3CX v11 SP3 and since then our phones Yealink T26/T28 will not get the correct time. I had even changed the NTP to 0.pool.ntp.org just in case and still the time does not update. No changes to the network. It did work before.
  2. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    Are your phones manually configured or provisioned with 3cx template? I am using T22/T28 with the x.x.x.103 firmware as you are, and also v11 SP3, working normally...
