Solved Yealink t26p incorrect password and user
Discussion in '3CX Phone System - General' started by perdicaro, Feb 2, 2017.
  1. perdicaro
    Jun 1, 2013
    26
    Having supplied the telephone and took the username and password that gives 3cx I can not log in anymore remotely 192.168.1.11 in your phone to set it up, password defalut has changed and no longer accepts admin / admin, and even those that I assign 3cx from the panel, how can I do?
  2. GiannosC_3CX
    GiannosC_3CX Guest
    The 3CX Phone system changes the default password to a new one for security reasons.
    Did you try to change the phone web page password on tab Phone Provisioning and re-provision it?
  3. perdicaro
    Jun 1, 2013
    26
    yes, but password incorrect again
  4. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    109
    40
    Did you go to the phones tab and reprovision the phone?
  5. GiannosC_3CX
    GiannosC_3CX Guest
    Please note, supported browsers to login on your management console are Chrome, EDGE and Firefox. Did you use one of them?
  6. perdicaro
    Jun 1, 2013
    26
    i use crhome, i try again whit the password and username than 3cx console give me, no workin, try also to reset yealink and reinstall 3cx reprovisoring no work
  7. jbryant84
    Apr 6, 2016
    109
    40
    The username is admin and the password is on the Phone Provisioning tab, the login is NOT the credentials on the first tab in the Extension options.
  8. perdicaro
    Jun 1, 2013
    26
    ok now i take the correct password from "Phone Web Page Password" Thnx jbryant84! now work:)
    #8 perdicaro, Feb 2, 2017
