Yealink T26P Page not working
Discussion in '3CX Phone System - General' started by neville, May 14, 2012.
  1. neville
    neville New Member
    Apr 23, 2012
    231
    43
    I have one T26P that page is not working on. I see AllPage:pG802 displayed for an instant and then the phone hangs up. Others are working fine. I am running the latest V.10 and version 6.61.0.70 on the Yealinks.
    Any ideas would be appreciated.
  2. neville
    neville New Member
    Apr 23, 2012
    231
    43
    Solved. Had 3CXphone on the same extension. Disable that and it work now.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    Good to know. So the 3cxPhone was "answering the call"...
  4. neville
    neville New Member
    Apr 23, 2012
    231
    43
    No, it seemed to be disconnecting the call. I will test more later and see if that is what was happening.
  5. neville
    neville New Member
    Apr 23, 2012
    231
    43
    Craigreilly, you are correct. The 3CXphone is answering the call. Good to know.
