Yealink T26P supported... illusion ??
Discussion in '3CX Phone System - General' started by itgs, Feb 14, 2017.
  1. itgs
    Nov 8, 2008
    57
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,199
    188
    The 3CX supported firmware versions are often not listed on Yealink's website. So typically you would just provision the phone with whatever firmware it is currently on and then upgrade it from the console.
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    That can be confirmed on their forum:
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,479
    466
    You can download the latest firmware from the updates section of the management console. It can be found at:
    C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\%provisioning_folder%\firmware_new
    for linux:
    /var/lib/3cxpbx/Instance1/Data/Http/Interface/provisioning/%RandomFolder%/firmware_new/Yealink
    You can get it from there and update your phones
  5. fred_gallon
    Nov 28, 2013
    7
    I'd strongly discourage to install the lastest firmware for the T-26P - it locks up the phones every now and then, very slow respond-times, reboots randomly, keeps ringing though the call has been finished since minutes, ...
    I'm looking to find a previous version of the firmware and will install it.
  6. itgs
    Nov 8, 2008
    57
    Hi Fred !
    Could you tell me wich version are you talking ?
    I installed the 6.73.0.50 and all is working fine.
    I'm evaluating to install 6.73.0.60 because 3CX notify that previous version is not supported (check image attach).
    Thank you
  7. jhoneck@honeckoil.com
    Feb 19, 2009
    How can you manually update the firmware if you system is running on Linux in the cloud on OVH? I have one T26P that refuses to update from 6.73.0.50 by provisioning.
  8. YiannisH_3CX
    May 10, 2016
    6,479
    466
    If you have SSH access you can follow the path provided above for linux. You will find the firmware listed under there.
