Yealink T28 and 3cx Forbidden outbound call
Discussion in '3CX Phone System - General' started by Viperian, Sep 12, 2012.
  1. Viperian
    Sep 12, 2012
    Voip provider is NEXVORTEX, which, is registered and able to send and recvieve phone calls. PBX is 3CX V10 witch I have 41 extensions registered. Some can make outbound phone calls and some cannot. All parameters seem to be configured correctly.
    For example on the same phone I have 2 accounts setup. Line 1 can recieve calls, but, not make outgoing. Line 2 with all the same parameters can make and recieve calls. Line 1 get a forbidden message displayed and closes the call.
    Read out is as follows:
    02:34:31.815 [CM502001]: Source info: From: "Anonymous"<sip:anonymous@anonymous.invalid>;tag=1569374956<sip:xxxxxxxxxx@192.168.2.3>
    02:34:31.815 [CM503013]: Call(176): Incoming call rejected, caller is unknown; msg=SipReq: INVITE xxxxxxxxxx@192.168.2.3 tid=1825716638 cseq=INVITE contact=1000@192.168.2.10:5062 / 2 from(wire)
    02:34:31.613 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:xxxxxxxxxx@192.168.2.3 SIP/2.0
    Via: SIP/2.0/UDP 192.168.2.10:5062;branch=z9hG4bK741422425
    Max-Forwards: 70
    Contact: <sip:1000@192.168.2.10:5062>
    To: <sip:xxxxxxxxxx@192.168.2.3>
    Call-ID: 1192458159@192.168.2.10
    CSeq: 1 INVITE
    Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
    Supported: replaces
    User-Agent: Yealink SIP-T28P 2.61.0.80
    Allow-Events: talk, hold, conference, refer, check-sync
    Privacy: id
    P-Preferred-Identity: <sip:1000@192.168.2.3>
    Content-Length: 0
    02:34:31.613 [CM302001]: Authorization system can not identify source of: SipReq: INVITE xxxxxxxxxx@192.168.2.3 tid=741422425 cseq=INVITE contact=1000@192.168.2.10:5062 / 1 from(wire)
    Any ideas? Really appreciate the help.
    Also, I had to uninstall at one point IIS and upon reinstall my Hotel Module, Softphone, and Voicemail never worked again. Must have something to do with port 5000 binding in IIS but I can not edit the Port under the binding it just states *4515 in the binding field and blank in all the other fields, any ideas?
    10,368
    229
    You've X'd out quite a bit so it's hard to get an idea what is being called.
    I question the "anonymous" part. Where does that come from? Do you see that on calls from the other line?
    the key line is this...
    Compare the INVITE on a working and non-working call.
  3. Viperian
    Sep 12, 2012
    Thanks for the response. I only X'ed out a 10 digit phone#. Still havnt been able to figure out why some lines randomly can make a call outbound and recieve while, some only take calls and cant do anything outbound.
    This is a print out of a line on the same phone, line 2 (can make calls externally) the previous print out was of line 1
    20:51:37.374 [CM503008]: Call(101): Call is terminated
    20:51:23.358 [CM503025]: Call(101): Calling VoIPline:9174977753@(Ln.10001@NexVortex)@[Dev:sip:wr9320QQTz@66.23.129.253:5060]
    20:51:23.309 [CM503026]: Call(101): Target is not available: Unknown:9174977753 dialed on (AnyLine@Nesva Smartnode 4940)
    20:51:23.309 [CM303003]: There are no available outbound lines on gateway Nesva Smartnode 4940 at this time.
    20:51:23.309 [CM503004]: Call(101): Route 1: VoIPline:9174977753@(Ln.10001@NexVortex)@[Dev:sip:wr9320QQTz@66.23.129.253:5060]
    20:51:23.308 [CM503010]: Making route(s) to <sip:9174977753@192.168.2.3>
    20:51:23.307 [CM505001]: Ext.1001: Device info: Device Identified: [Man: Yealink;Mod: T28;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T28P 2.61.0.80] PBX contact: [sip:1001@192.168.2.3:5060]
    20:51:23.306 [CM503001]: Call(101): Incoming call from Ext.1001 to <sip:9174977753@192.168.2.3>
    20:50:59.084 [CM503008]: Call(100): Call is terminated
    20:50:52.055 Currently active calls - 1: [100]
    20:50:48.266 [CM503025]: Call(100): Calling VoIPline:9174977753@(Ln.10001@NexVortex)@[Dev:sip:wr9320QQTz@66.23.129.253:5060]
    20:50:48.218 [CM503026]: Call(100): Target is not available: Unknown:9174977753 dialed on (AnyLine@Nesva Smartnode 4940)
    20:50:48.217 [CM303003]: There are no available outbound lines on gateway Nesva Smartnode 4940 at this time.
    20:50:48.217 [CM503004]: Call(100): Route 1: VoIPline:9174977753@(Ln.10001@NexVortex)@[Dev:sip:wr9320QQTz@66.23.129.253:5060]
    20:50:48.216 [CM503010]: Making route(s) to <sip:9174977753@192.168.2.3>
    20:50:48.215 [CM505001]: Ext.1001: Device info: Device Identified: [Man: Yealink;Mod: T28;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T28P 2.61.0.80] PBX contact: [sip:1001@192.168.2.3:5060]
    20:50:48.214 [CM503001]: Call(100): Incoming call from Ext.1001 to <sip:9174977753@192.168.2.3>
    20:50:39.145 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:9174977753@192.168.2.3 SIP/2.0
    Via: SIP/2.0/UDP 192.168.2.10:5062;branch=z9hG4bK1362734237
    Max-Forwards: 70
    To: <sip:9174977753@192.168.2.3>
    From: "Anonymous"<sip:anonymous@anonymous.invalid>;tag=1237588732
    Call-ID: 847583599@192.168.2.10
    CSeq: 1 INVITE
    Supported: replaces
    Privacy: id
    Content-Length: 0
  4. leejor
    10,368
    229
    Are you putting in the words "anonymous", or is that what is actually in the log? That is a bit of a worry.
  5. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    Can you provide the scenario on the below? In other words, describe the call sequence of events:
    1. call comes into x from extension y
    2, extension y is not there, so call is forwarded to .......
    This would help underastand the flow.
    nexVortex is a SIP trunking agent and I am a little confused with how the Patton 4940 (PRI device) enters into the picture -
    "There are no available outbound lines on gateway Nesva Smartnode 4940 at this time"
