Yealink T28 Lines?
Discussion in '3CX Phone System - General' started by seanbts, Oct 19, 2010.
  1. seanbts
    Oct 12, 2010
    34
    Hi All,
    I have a Yealink T28P which has six lines on the phone, how do I configure these accounts .....We have 6 lines with our VOIP Provider, how is this configured within 3CX and the phone?
    Cheers
  2. taurusgd
    Oct 5, 2010
    17
    You only use line 1 and set up the DID pointing to the operator or extensions as needed for the other numbers.
    We have 8 concurrent lines with our voip supplier.
