Yealink T28 speaker phone echo
Discussion in '3CX Phone System - General' started by HurdIT, Jun 28, 2011.
  1. HurdIT
    Apr 13, 2011
    11
    Has anyone had the issue of Echo and sounding distant on the Yealink T28 phones with 3CX? I'm pretty sure it's a phone issue. When I'm not on speakerphone it's perfectly fine. Any suggestions?
  2. hinzinho
    Aug 5, 2011
    I am having this exact issue. Any luck in fixing this?
  3. willow
    willow Member
    Mar 1, 2011
    471
    try turning the volume down. I use T28's all the time and have not heard of the issue. are you using the 60.110 release of firmware.
