Yealink T2x t3x lables
Discussion in '3CX Phone System - General' started by netswork, Feb 22, 2012.
  1. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Does anyone have a good way to create labels for these t38 phones? I found yealinks word document with labels on them. they don't match up exactly to the phone but that can be fixed easily. Problem I see is cutting the little holes for all these buttons. I have new install to do soon with 90 phones and need an efficient way to print and cut these labels. Any advice would be great. Thanks.
  2. kylejoe1
    Feb 15, 2011
    66
    Good luck, baffles the mind Yealink decided on those types of buttons in the first place, it's 2012.
    Although, they have a sidecar for $140 http://yealink.com/index.php/Products/detail/id/16
    that has electronic LCD buttons for t26, t28 and T38, but....again goofy to have to tell customer "use first 10 buttons as manual write-in entries but with the attached sidecar...its LCD!"
    The T22 and this sidecar would make sense but oops, can't use with that model and it would make for a $225 phone.
    Yealink T38 should have been all LCD, instead its like a nice new car with 4 small spare tires all around. Most businesses have LCD, we can't go and sell them these phones and expect them to write in speed dials or BLF do we? Hopefully their next model fixes this issue. T4X, where cost efficiency and technology merge!
    Saw this Mitel phone the other day, pretty slick: http://www.mitel.com/resources/1206_6618-PN%2051015312RC-EN_lr.pdf, almost like an iPad touch screen. I think it is worth more then my car.
  3. Ian Joyce
    Oct 9, 2009
    51
    http://labels.desi.com/product-exec/product_id/2811/nm/Yealink_SIP_T28P_SIP_T26P
