Yealink T38 3CX phonebook or LDAP search
Discussion in '3CX Phone System - General' started by nbrown, May 21, 2014.
  1. nbrown
    May 6, 2014
    22
    Hi, I'm trying a Yealink T38 IP Phone (firmware 38.70.0.198) but I have one big issue, the 3CX phonebook doesn't show numbers only null against names and the built in LDAP lookup of the phone just won't show any results against active directory. Either way I have no contacts that I can use. The 3CX phonebook works fine for Aastra and Windows phones so I know it's OK.
    Can anyone help?
  2. nbrown
    May 6, 2014
    22
    I've just realised that the XML output for the phonebook only has mobile phone numbers, it doesn't include any others at all, how do I correct this?
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,956
    180
    You could roll your own...
    We take the 3cx xml file (which is extensions - we don't use the phonebook) and merge it with Active Directory.
  4. nbrown
    May 6, 2014
    22
    We already have the extensions in AD, but the LDAP lookup/search on the Yealink phones just won't work, each time it comes back with no contacts.
    For now we've changed the phone book so extension numbers are in the mobiles column and it works, just not ideal.
  5. nbrown
    May 6, 2014
    22
    It was a firmware issue, had to update to 32.70.0.130 to get it to work.
