Yealink T38 Shoulder Rest
Discussion in '3CX Phone System - General' started by craigreilly, May 22, 2012.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,407
    274
    Has anyone found a suitable Shoulder Rest for the T38's?
  2. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    I looked for one as well, never did get one though. Bit the bullet and got the receptionist a Jabra wireless headset and an EHS adapter.....now I'm a super hero in her eyes. :D
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Which Jabra. if I may ask?
    Thanks,
  4. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    It's the GN9350e connected through a Yealink EHS36
    George
  5. lneblett
    Sep 7, 2010
    2,083
    61
    Thanks. Does the EHS adatper eliminate the need for a handset lifter? I assume it comes with a cable that is compatible to and connects with the EHS, correct?
    I have someone who is looking and you may have saved me a bunch of time.
  6. craigreilly
    Feb 1, 2012
    3,407
    274
    I have 3 people in a call center like environment and I have suggested headsets to them. Maybe that will suffice.
    A few others still want shoulder rests.
  7. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    Correct, no need for a handset lifter. the headset and EHS come with the necessary cables.
    Of course all phones are different, I'm using a Yealink T38G
    George
