Yealink T38G Template BETA
Discussion in '3CX Phone System - General' started by nbailey, Jun 29, 2011.
  1. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Hello All,
    If you use the Yealink T38G please follow this link to a BETA of the provisioning template for V10 3CX Phone System.
    http://www.3cx.com/forums/yealink-t38g-template-beta-20894.html
    Thanks,
    Nate
