Yealink T42G
Discussion in '3CX Phone System - General' started by steve matten, Mar 3, 2017.
  1. steve matten
    Dec 19, 2016
    17
    We have 50 new Yealink T42G phones in boxes ready to deploy. My 3CX Phone Management page says "Not Supported 29.80.0.95". This is a new installation, do I need to send them back? What does it mean "No longer Supported"?
  2. teldata1
    Aug 24, 2015
    63
    That means the firmware currently on the phones is an earlier version. They are 100% supported and work great with 3CX.
  3. LiscardGP
    Sep 29, 2011
    54
    Make sure you have the latest SP5 installed.
    So when you connected the phones to the LAN did the appear in the Phones node? Only asking as mine do not. Hopefully you will be OK.
  4. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Yeah, what TelData said. Upgrade the firmware otherwise remote provisioning probably won't work.
