Yealink T46 firmware update
Discussion in '3CX Phone System - General' started by NickD_3CX, Mar 30, 2016.
  1. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,246
    61
    At the moment, you can only push new firmware onto local phones, not ones that are provisioned through a SBC. There might something though you can try, assuming you provisioned the phone using the default template, not manually:
    1) Go into the extension settings -> phone provisioning tab, and here in the "Provisioning Method" drop-down select "Local Extension", then press OK.
    2) Go to the "Phones" node, highlight the extension and now "Upgrade Firmware" might be enabled.
    3) If it is press it and download the firmware. Once it downloads, the phone will do nothing.
    4) Go and undo all the changes you made in step #1.
    5) Reboot the phone manually and on boot, it should look for new firmware on the server that, because you downloaded it in step #2, it should find and install it.
    To be honest I have not tried this but I have a feeling it may work.
  2. NickD_3CX
    Jun 2, 2014
    1,246
    61
    Steps #1-#4 only need to be done once per phone model, then you just reboot all phones, so if you have 100 phones of the same model, you do #1-#4 once, then reboot all 100 phones.
    In steps #1-#4, you must NOT reprovision or restart the phones otherwise indeed they will pick up the settings you mentioned, but if you don't, this shouldn't happen. Basically all you are doing is 'tricking' the Phone System into downloading the firmware from the repository, that is all.
