Yealink T46G CTI and headset for outgoing calls
Discussion in '3CX Phone System - General' started by Frank D, May 2, 2017.
  1. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
    we running into the following issue making calls using CTI with a connected headset:
    The telephone will dial the number, but it will switch from the headset (same behaviour for cord headset YHS32 and bluetooth headset) to the speakerphone. The headset led is active (green) and than goes inactive while placing the call. In order to get the phone on the headset we have to press the headset button on the phone again.
    Incoming calls work fine on the headset.
    We upgraded the firmware to 28.81.0.70 (from 28.73.0.48) but nothing changed. We are using 3cx V12.
    Maybe it is because 3cx V12 uses the MAKE call and not full fledged CTI for Yealink phones?
    Any help appreciated
    Best regards Frank
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hi @Frank D,
    What headsets do you use? Do they have function buttons?
  3. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
    Hi Panayiotis,
    We experience the same behaviour for varios Bluetooht Headsets, connected via the Bluetooth Dongle. as well as the officical Yealink YHS32, connected via a normal cord attached to the headset port.
    The Bluetooth headsets do have function buttons, but we were not successfull in figuring it out (accepting calls works fine). The Yealink YHS32 does not feature a function button.
  4. Panayiotis_3CX
    Apr 26, 2017
    165
    7
    @Frank D
    As it seems the call routing is device dependent. We do not have a specific setting for this, and as we cannot test it at the moment, it would be best if you seek assistance with Yealink or someone who already faced a similar issue in our forum.
  5. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
