Yealink T46G + EXP40 + EHS36 + Jabra pro 9450 + FW 28.82.0.20 = no pickup
Discussion in '3CX Phone System - General' started by Brad Cann, Nov 27, 2017.
  1. Brad Cann
    Brad Cann New Member
    May 5, 2017
    109
    15
    Gday all,
    so with the above combo, we cannot pickup calls on the Jabra Pro 9450, revert back to firmware on T46G phone to 28.81.0.110 and the jabra picks up fine.
    3cx is latest version (15.5 sp2) No custom templates. If we bypass the exp40 jabra pro works (so ehs straight into ext port), if we piggy back through the EXP40 no go. If we revert to 28.81.0.110 on T46G no issues.
    With new firmware Jabra shows green light on headset base phone icon to indicate it has recieved the pickup signal from the wireless headset.
    What gives?
  2. V..
    V..
    Feb 14, 2017
    74
    28
    Have you tried updating the firmware of the EXP40?
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello @Brad Cann
    Please note that Yealink has confirmed this issue with their latest firmware and they are working on a fix for their next firmware update.
  4. Brad Cann
    May 5, 2017
    109
    15
    great thanks yiannish.
  5. Brad Cann
    May 5, 2017
    109
    15
    appears they have released a new firmware T46-28.82.0.30.rom which fixes it will test and get back.
  6. Brad Cann
    May 5, 2017
    109
    15
    nope still not fixed.
  7. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,338
    76
    3CX does not test the EHS module and how/if it works with headsets. I seem to remember reading something about this a few weeks ago but for the life of me I kind find the Yealink forum thread I had read it in...
    As 3CX does not test this aspect of firmware, I would suggest, if you have not done so already, to also open a discussion on the Yealink forums as well. If they address it in a newer firmware, at some point we will also get that firmware in the 3CX repositories as well.
