Yealink T46G Not Auto-Provisioning with Hot Desk
Discussion in '3CX Phone System - General' started by Michigander, Jan 5, 2018.
  1. Michigander
    Sep 22, 2016
    I have a Yealink T46G set up as a hotdesk extension, our only one actually. I followed the steps in the "how to" video () just to make sure everything was done properly but the phone does not auto-provision after a log in/out. I can log in with the dial code and I get confirmation that the login was successful, but the phone never reprovisions. If I go in and manually force a reprovision it works. But then when I log out (again, system says successfully) I have the same issue. It is on the same subnet and VLAN as the 3CX server, and if I manually initiate the provisioning it works fine. Any ideas as to what I'm missing?
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    877
    135
  3. eddv123
    eddv123 Active Member
    Aug 15, 2017
    914
    139
  4. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    I had similar problems. My BLF keys wouldn't propagate and so I got rid of hotdesk on that phone.
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hello @Michigander
    As mentioned please make sure that you are running the latest supported firmware for these phones.
    You can find the latest supported firmware here. There is also a written guide you can follow to make sure the phones are correctly set up.
  6. Michigander
    Sep 22, 2016
    All of our T46G's are on 28.82.0.20 firmware using the default 3CX templates. System prompts are up to date (ran into that issue initially). I've factory reset the phone three times and re-setup hotdesking three times just to make sure I was following the guide correctly. Everything works except the automatic reprovisioning. If I use the dial code to log someone in and then force a reprovision it updates correctly. If I then log them out and force a reprovision it updates correctly. It just won't do it on its own, even if left overnight.
    Edit: We do have the Pro license. Also, the hotdesking tab in the Admin console updates as soon as I do a log in or log out on the phone, but the provisioning just doesn't happen.
  7. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Mega dittos. There are problems with this phone and firmware. Not thoroughly tested.
    The BLF keys don't provision correctly with hotdesk.
    #7 jimbo59, Jan 9, 2018
  8. YiannisH_3CX
    May 10, 2016
    4,443
    282
    @Michigander
    The phone should not require a restart to apply the provisioning from hotdesking. I have tried replicating the issue with the exact model but i was not able to. the phone applies the settings automatically right after the voicemail pin is provided. In order to further troubleshoot we will need to review your configuration files. Please check your inbox for detailed instruction of the required files.
    @jimbo59
    As mentioned above i have tried the specific phone and provisioning with blf buttons works as intended. Perhaps Michigander can tell us if blf buttons work for him after the forced provisioning at least so we can see if this is a general issue or specific to your installation.
