Yealink T46G Phones Don't Hold Firmware
Discussion in '3CX Phone System - General' started by Drew9213, Jul 19, 2017.
  1. Drew9213
    Sep 16, 2015
    62
    I Have a large number of Yealink T46G phones on old firmware and I have been upgrading them manually to the newest firmware available from the Yealink website. 6 out of the 30 phones will not hold the new firmware. These phones will take the firmware upgrade and then immediately reboot and revert to the old firmware.
  2. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    The firmware will not be supported with 3cx........... Best way to do it manually update the firmware to what 3cx supports.
  3. Drew9213
    Sep 16, 2015
    62
    I know 3CX doesn't technically support the firmware, but I have a significant number of phones running the firmware just fine. The issue is that the phones themselves will not hold the firmware that I give them. It doesn't matter which firmware I give them, they immediately reboot and revert their firmware back to what they were on.
  4. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    Factory reset the phone and try the supported firmware and see if that works?
  5. teldata1
    Aug 24, 2015
    63
    I've experienced this. You need to remove the provisioning URL from the phone in each phones GUI. If the new firmware is so valuable to you that you don't need auto provisioning, then go for it.
