YeaLink T46G Tansfer to Prefix+BLF
Discussion in '3CX Phone System - General' started by tsukraw, Jan 14, 2014.
  1. tsukraw
    tsukraw New Member
    Mar 9, 2012
    191
    9
    So i have a customer who wants a Xfer VM button on there phones.
    After doing all research i found there is a Prefix option for a DSSkey on the YeaLink phones.
    I programmed a PreFix key as *4
    If i press Prefix + BLF i go to the BLF extensions voicemail as expected....
    However if i press Transfer + Prefix + BLF the caller gets transferred to (Please enter extension number and then press #) like it got sent to 99 instead of the voicemail of the extension....
    Has anyone ran into this before or attempted it?
    We are running 3CX V12 SP3
    Yealink T46G running firmware 28.71.0.176
    Thank you
  2. tsukraw
    tsukraw New Member
    Mar 9, 2012
    191
    9
    Actually after a little closer looking at what happens when you press Transfer + Prefix + BLF. The phone is actually sending Transfer *4 it is missing the BLF number. Not sure if that helps anyone narrow down what i am doing wrong
  3. mlump
    mlump New Member
    Feb 24, 2012
    113
    I have attempted to use the prefix button as you have mentioned, unfortunately it seems that if there is no active call it prefixes just fine, but if there is an active call the prefix button sends the digits immediately. I have not found a way around this.
  4. tsukraw
    tsukraw New Member
    Mar 9, 2012
    191
    9
    Wouldn't you say this is a bug with YeaLink since you get 2 different results depending on the state of the phone?
  5. mlump
    mlump New Member
    Feb 24, 2012
    113
    possibly, i did not investigate it that far as i was performing the testing more out of my own curiosity than trying to complete a request from one of my customers.
