- Joined
- Jan 25, 2017
- Messages
- 2
- Reaction score
- 0
i have been struggling for a few hours to get this working and it is a pain.
i plugged in my t46s in to a poe switch and turned on fine and it came with FW 66.81.0.110 and it did not provision at all.
i even updated it to 66.81.0.60 as the website shows that is the minimum firmware. and still it is not provisioned
as i was playing around with it i noticed that upon factory reset it would say 'sending provision request' and after 1 second 'update failed'
then when i do a normal reboot i see for a split second network unavailable and then the messages above.
so i added a reservation on my DHCP to change the ip address so that i can make sure it is talking properly. and then after a reboot i still see the same messages. and after checking the IP it has changed to what i had set it to
any thoughts
if it means anything i have tried a new extension as well as one that is already in use. and same issues
another side note this is my first yealink phone. i currently have 4 cisco phones.
any thoughts
