- Joined
- Jul 10, 2018
- Messages
- 25
- Reaction score
- 10
Hi there,
i tried to configure a yealink T46S without using SBC to connect to 3CX securely via DIRECT provisioning.
I customized the template to use Port tcp/5061 and SRTP in compulsory-mode. This works fine.
I also noticed that i need to configure the outbound proxy pointing to the 3cx, otherwise the calls are running a while after i already hung up. Audio, signalling (ringing of phone) and dialing works without problems.
But with enabling TLS as transport_type on the phone, the BLF-Key doesnt work any more.
I cannot see a green or red light, just a red X on the icon. On the 3cx Phoneclient and the 3CX app i see the extension marked as green. Is there anything i missed to configure to get BLF with TLS working?
V15.6
Firewall Check on 3CX OK
All Template updates installed (cloned the newest)
current supported FW for yealink installed.
Regards,
Thomas
V15.6
Regards,
Thomas
