Yealink T48G - cannot retrieve parked call
Discussion in '3CX Phone System - General' started by nathanmsaunders, Jan 5, 2017.
  1. nathanmsaunders
    Aug 21, 2016
    32
    Hi Guys,
    i am trying to setup a yealink t48g with 3cx however i am unable to retreive a parked call on the handset
    when a call comes in i can hit park and it will transfer the call to the shared park however if i press the same shared park dsskey i pressed to put them on park it just dials SP1 and doesnt retrieve the call.
    i have tested picking up the same call i placed on park via another snom phone at it works fine. am i doing something wrong? i configured the handset with the template from 3cx v15 SP4.
    see attached photo from the phone system it self and the handset
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @nathanmsaunders
    Just tested with a T48 with firmware 35.80.0.130 and i can park and pick up a call from shared parking with no problem.
    Called the extension, answered the call and then pressed BLF key SP1. The call got parked and i picked it up using the same BLF.
    Are the extensions local or remote?
  3. nathanmsaunders
    Aug 21, 2016
    32
    Hi there,
    Seems what is happening is when the phone is provisioned via the default template the park extensions are not registering however if I go into the web page of the handset after its provisioned and click the buttons tab then click apply they all turn green on the handset and then work.
    The handsets are remote. Running latest firmware from the yealink website
    Did you deploy yours via the template or manually.
    It doesn't seem to activate the provisionised settings on the handset until I log in an hit apply
    #3 nathanmsaunders, Jan 7, 2017
  4. YiannisH_3CX
    May 10, 2016
    4,349
    274
    mine was provisioned with default template. When you say latest firmware from Yealink website which firmware is that? Is it the same mentioned i above?
