Solved Yealink t48g not working with 3cx.
Discussion in '3CX Phone System - General' started by Dreamwebs, Mar 2, 2017.
  1. Dreamwebs
    Feb 19, 2017
    10
    I have a new Yealink T48G.
    I installed the Yealink trough the provisioning link, but i get an error:
    Register Status: Register Failed
    I don't know why, the username and password are 100% correct.
    Does anybody have tips what more to check to get it working?
    Thank you!
    [​IMG]
    11,076
    323
    If you check the 3CX Activity log, you can check for a registration attempt, and, if there is, if it is a password issue, or something else. If there is no attempt at registration, then the set is trying an incorrect address. Is it a "local" set?
    craigreilly likes this.
  3. Dreamwebs
    Feb 19, 2017
    10
    Thank you leejor, good idea!
    I installed 3cx on a external debian server and use the yealink in my office.
    [​IMG]
  4. Dreamwebs
    Feb 19, 2017
    10
    This was in the logs:
    SIP request (REGISTER) from 84.28.236.1 was rejected. Reason: Block WAN requests is ON.
  5. Dreamwebs
    Feb 19, 2017
    10
    Found it!
    Disallow use of extension outside the LAN was turned on.
    Thank you so much!
