Yealink T48GN Compatability
Discussion in '3CX Phone System - General' started by bannerks, Apr 27, 2014.
  1. bannerks
    Apr 27, 2014
    15
    Does 3CX supporta Yealink T48GN. Will it auto provision that model.
    K
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    That isnt a supported phone however a phone doesnt have to be a supported handset to auto provision.
    http://www.3cx.com/support/
