Yealink Template features
Discussion in 'Ideas' started by DeepNet Support, Sep 1, 2017.
Yealink Template features 5 5 5votes
5/5, 5 votes
  1. DeepNet Support
    Sep 1, 2017
    Greetings,
    Feature request ONE
    I would love it if you could include two features in the template on the PBX Phone Provisioning tab for configuration.
    A recent template update added a bunch of features I usually create a custom template for but one feature I still need to adjust with a custom template.
    That is the Extended DSS Key Length
    Line 2202
    # Only applicable to SIP-T46G/T48G/T29G/T48S/T46S IP phones
    features.config_dsskey_length = 1
    By default it is set to 0 ( disabled ) If we could toggle enabling that via the PBX Phone Provisioning tab that would eliminate the need for me to use custom templates.
    Feature request TWO
    Also, along the same lines, if you could make it so we could enable or disable the "Beep" when there are unread messages, we would greatly appreciate it.
    Having both of those options available from the PBX would enable us to not have to use custom templates to configure those settings.
