Yealink Template Update
Discussion in '3CX Phone System - General' started by interactive9, Jul 24, 2017.
  1. interactive9
    Oct 26, 2015
    15
    Good morning, does anyone know what the differences are in the new updated Yealink template?
    We have a fair few clients using Yealink phones with custom templates.
    I am assuming that if I download this update it will not have any effect on my custom templates.
    It would seem alot easier for me to just update my custom templates manually to reflect the changes in the update?
    This will save lots of time compared to creating a new template and reprovsioning.
  2. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    Asked 3CX for a change log page awhile ago but didn't get a response here is diff:
    < <version>66694</version>
    > <version>66695</version>
    #Configure the WAN port type; 0-DHCP (default), 1-PPPoE, 2-Static IP Address;
    #Require reboot;
    989c989
    < network.internet_port.type = 0
    #Enable or disable the phone to dial the IP address directly; 0-Disabled, 1-Enabled (default);
    1977c1977
    < features.direct_ip_call_enable =
    > features.direct_ip_call_enable = 0
    #Enable or disable the phone to only accept the message from the server; 0-Disabled (default), 1-Enabled;
    2733c2733
    < account.1.sip_trust_ctrl =
    > account.1.sip_trust_ctrl = 1
