yealink templates
Discussion in '3CX Phone System - General' started by netswork, Apr 10, 2015.
  1. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Does anyone know how to turn off the voicemail notification pop-up on the t48 display? I was able to disable the missed calls pop-up but I cant find an entry in the template related to the voicemail notification.
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    First step is the phone need to have one of the 73 series firmwares (latest supported is 73) and can configure it in the template or manually through the web interface. The 73 firmware allows this to be turned off or on. The 72 firmware releases default to on and can't be turned off.
    If the template doesn't have this line just add it in to disable it:
    features.missed_call_popup.enable = 0
    Or through the web interface:
    Features->Notification Popups->
    Display Missed Call Popup
